Keyi just released a software update to fix this issue. Does your Loona recharge successfully after the update?When loona run out of power, it cannot automatically returns to the charger and recharges itself.
why ? When it can fix this issue?
Thanks a lot .
Simon .
Thanks for the feedback on this. Glad yours updated safely with no issues. I’ll probably try updating one of mine to see the difference. Hopefully they improve self charging in future updatesAfter updating... loona almost successfully self charge BUT not quite I have to assist every time![]()
First of all bluetooth has no proximity detection. Its like wifi. if its in range it connects and it cant know how far the device is. So the idea itself wont work. Second, the charging doc doesn't have a bluetooth hardware to connect to the bot. The bot has a LiDar sensor which can use laser to map the 3D depth of the view area. I believe their plan is to use it to map the whole house/room and it could remember the position of the charger. This is how liDar robot vacuum cleaners work now. But I am just speculating at this point. But if technically its possible according to my understanding as its already working fine with robot vacuums without a fail every time. But the vacuum bots lidar spins really fast so it can get a real-time map of where it is in the house while it moves. But in Loona its static on its frontside so it cant be that realtime. But hopefully it will get better as they have enough hardware onboard. But if it was opensource, there could have been more fun and interesting stuff going around it as it have potential. But is seems Loona's trend is going down now. If you check the internet, all I see is their advertisements pushed once a week or so no user reviews or stuff from users anymore.Why not use the bluetooth on board to get him close enough to find it. We could add something to the charging station. If not that then the wifi. We can add something to the charger
Thanks for sharing this great tip Kan- will have to try this with mine!My Loona can't automatically go to charge, even though the charging station is right in front of her. I have to place a lamp near the charging station to make its logo visible,.
I believe Loona's charging algorithm might improve some image preprocessing when it's searching for the station.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
