Failed update will not complete.
Screen says updating, but will not complete or start up
I’ve had this happen. Try holding down on Loona’s power button for 2 minutes. You may have to try this multiple times.
If that doesn’t work try plugging Loona into power using the USB cable and pressing down on the power button for 2 minutes.
Otherwise let the battery drain and once Loona has powered off try charging using the USB cable and see if losing power caused her to reset.
