Question about the StikZAP Error with 32MB MemoryStick for AIBO ERF-210AW06J
  • Thread starter Thread starter Inagaki
  • Start date Start date
  • 558
I
Inagaki
Guest
I am attempting to back up my AIBO-WARE and have acquired a used SONY CLIE PEG-NX70V. Using StikZap (version 1.4), I tried to load the STIKSAFE.BIN file of "Orikou AIBO: ERF-210AW06J," which I had previously saved on a SONY genuine 32MB Memory Stick (MSA-32A), by pressing the USE Safety button. However, I encountered the error message: "Internal Error - can't write bad 2 bits for set," and the process failed.
I would greatly appreciate any insights into resolving this issue.
For reference, I successfully executed ZapPMS on the same hardware setup, with no issues regarding PMS-type security settings. Furthermore, after saving DogsLife RCODE and other necessary files onto the Memory Stick, my ERS-210 boots and operates without any problems.
Prior to this issue, I also attempted the same process using a SONY genuine PSP MEMORY STICK DUO (PSP-M32) with a Memory Stick Adaptor (MSAC-M2), but encountered the same error. At that point, I suspected that the PSP Duo format might be causing the issue and retried with the standard MSA-32, but unfortunately, the result remained unchanged.
Additionally, my initial attempt using an MSA-16A was successful, without any issues. However, since the Orikou AIBO: ERF-210AW06J file requires 32MB of storage, I am concerned about future storage limitations and attempted the process again with the 32MB Memory Stick, leading to the current issue.
If anyone has any suggestions or solutions, I would greatly appreciate your help. Thank you!
I’m having a similar problem myself. I get an error saying “can’t write bad 2 bits for set,” and I can’t proceed any further. I hope there’s a good solution to this...
I was able to resolve the issue.
When this error occurs, you need to reset the CLIE once.
To reset it, insert a pin into the small hole on the back.
After that, format the card using the CLIE, then launch Stickzap.
You can create a blank card using ZapPMS.
Glad you found a solution Aki!
I haven’t used a CLIE since I updated an ERS-7 over a decade ago to service pack 3 so wasn’t able to offer any advice.
