Vector ChatGPT tutorial: Pre-installed wire-pod server for Vector now available (2 Viewers)
You can purchase a server with pre-installed wire-pod for Vectors voice processing which requires no set up and is simply plug and play.
This tutorial even shows you how to integrate OpenAI’s ChatGPT with Vector so you can have a natural language conversation with Vector using non-native commands.
Open source version of wire-pod.
I accidentally installed wire pod 1.8 on my Vector 2.0 now his screen is black and his head is always down. Please help me fix it.
Try contacting this Vector wirepod seller who may be able to help you:
My Vector Bot is showing a phone with a flashing V, what do I do to fix it?
Double Press the Button, see if it goes into paring mode, then reconnect the bluetooth.
If that does not work, have you blocked the DDL/ANKI servers in your router?
